This is a clip from a Tubes song. About halfway through, where he sings “see the lightning and the picture show” something changes. Before that it sounds slightly more muffled and right at that spot it gets more clear. I’ve tried equalization on the first part to try and make it match but haven’t had much luck; I’m not even sure that’s what it needs. Can anyone tell what’s causing this and how I might repair repair it? I’ve checked every version of this song I could get my hands on and they all do it so it must be in the master. Thanks.
Yes the equalization has changed half-way through.
Could use Audacity’s spectral edit tools* so the spectrogram, (the equalization), is more consistent …
( * it’s like dodging & burning an image in photoshop ).
Thanks a lot Trebor. I’ll try it and report back.
Well I fixed it with the Spectral edit multi tool. I’m not exactly sure how I did it though. It was my first go at it and I just played with it till I got the sound I wanted. It seems like a great tool though and I’ll probably get better acquainted with it in the future. Muchos gracias!
Its creator made some YouTube demo videos … https://www.youtube.com/watch?v=A5ErzybkrGc
