Hello everyone. On a recent trip to Ireland, I recorded a number of performances by a band we were traveling with with a Tascam DR-05 field recorder. Each show was recorded in WAV form, 24-bit using the built in speakers. For what it is, the Tascam gave pretty good results. Good enough to provide a unique souvenir to our group of travelers. And that is my goal.
So now I have 5 shows that are anywhere from an hour to two in length that I need to clean up and split into tracks with my final goal of converting them into .mp3 tracks to share with the rest of our group of travelers, and the band.
My question to you is this. What would be the preferred method for handling this task. Should I perform all of my filtering to the one, long track first, then split the tracks into individual songs, or should the tracks be split first and then perform the edits? The editing that I’ll be doing will be in line with my Audacity skill level, which is a novice. Some of the shows were a bit bass heavy, so I’ll be trying to figure out how to remove a bit of that as well as checking for clicks and pops. Nothing too grand as my experience in this field and Audacity is very limited.
Thank you all very much for your thoughts. Thank you as well if you have any other suggestions or “must do’s” for cleaning up the tracks.
Jackie
Audacity 2.0.5
