Hello! I’m using a low-cost audio interface, XTUGA E-22.
Since version 4 supports ASIO, I’m testing using the ASIO4All driver and I was able to record on it.
But it has issue, it won’t directly record or play. It’s like loading first a second and then starting working.
If the problem is my audio interface, I’m considering upgrading to M-Audio M-Track Solo/Duo. I’m hoping that it will run smoothly.
There is a version of Audacity 3 which is compatible with ASIO … Download Audacity with ASIO – Leo Wattenberg
[ Audacity 4.0.0 is only about a month old, it has teething problems ]
Oh, I will check that one. Thank you!
