Hi,
Sorry if I am at the wrong adress, but my English is not to good, and I can’t find my way very well in all the supports.
I installed Audacity 2.1.1. and renewed my ffmpeg and lame mp3 library’s. I downloaded directly, not by zip. I use windows 7.
Since I did so I exported a file to WMA which is not recognised by Windows Media Player (vs 12). I never had that problem.
When I open the .wma file, an error code 0x8007000D is displayed. The webhelp site suggests that a wrong codex might be installed. sometimes a text is about tags.
When I open the properties > details of the file, all fields are empty (description, media, audio, etc) exept “File”; but I can’t change the values.
When I try to play the .wma file in Windows Media Centre, the error code is cood1059
When I export the same file to MP3, no problem: all media-details are completed; also when I convert i his file to WMA with Videosoft Free Studio, I can play the file in WMP, but the quality is less (128 bps in stead of 320 bps).
I tried to upload some screendumps as an .docx, or a .pdf file, but they are refused.
Since the same problem occurred when I did exactly the same on a different computer I thought maybe one of you can help me to solve this problem.
thank you for your support.
Ton Boon
