Hello.
Due to this, that I can’t load any plugins, which are not compatible with 64-bit version of Audacity, I have a little pleasure to You. Please, do You know some good Windows 64-bit compatible autotune vst plug-in? I can’t load now My old plugin, because is 32-bit.
Could You help Me please?
Thank You.
Marco
P.S: I’ll test It, if It is accessible. I am blind.
Audacity 3.0.3 is available both in 32 and 64 bit versions for Windows users.
So you could still use your old 32 bit plugins on the latest version of Audcaity.
[ I’m not sure if it is possible to safely have both 32 & 64 bit Audacity on the same computer: they could conflict ].
There is a free version of Grallion2 plugin which has autotune, (pitch correction).
https://www.auburnsounds.com/products/Graillon.html
It’s available in 32 & 64 bit, I can testify the 32 bit version works in Audacity on Windows.
Hi.
In some cases maybe It’ll be good idea to install 32-bit version.
In other side It’s a great to try some different VST plugin. So, I have tried to use Graillion. It is mostly accessible for me.
Big thanks to You.
