Windows 11, Disable Audio Enhancements
Windows 11…The USB-C port does not appear to have a way to disable Audio enhancements for my microphone or does it ? Does the USB standard port have Audio Enhancement disabling?? My flute notes can be much longer than allowed with AE enabled.
Thank you much.
There can be a second layer of “audio enhancements”,
sometimes called MaxxAudio, or DTS.
Trebor, Thank you. I looked but did not notice that for the USB-C mic. I do not know if a mic plugged into the USB port will have to same issue. The built in mic has an obvious way to disable audio enhancements but the gain is lower than want I would like. The USB-C mic hooked to my flute had more gain but the longer notes were truncated.
