Windows 11 compatibility check
Hi Team,
We are using Audacity v3.13 we would like to know whether the application is compatible with Windows 11 or not.
If not, we would need the latest upgrade for the application which will make the application compatible with the latest windows version.
I have had no problems with with earlier versions and windows 11 and the new 3.4.2 works Ok as well
