I recently got an HP Pavilion x360 with Windows 10 Home and tried multitrack recording using my Alpha Lexicon USB interface. I had always been able to record with the same setup with my old laptop and older Windows version (XP I believe).
Now anytime I record an additional track it plays back all warbled and seems to drop everything about a half step down (while the first track I play sounds fine). Here’s an example:
https://www.youtube.com/watch?v=STMiFUwKokM
By default Audacity would open with MME selected, but when I did so originally the first track would sound bad when monitoring it as I tried to record a new track (though playing that track on its own sounded fine). After switching to WindowsDirectSound, the first track now sounds fine but as mentioned above additional tracks sound bad.
Switching to WindowsWASAPI just gave me an “error opening sound device” message when I tried to play anything.
I downloaded the latest driver for Lexicon Alpha and have also tried changing the 48000, 44100, and 32000 Hz, but the issue persists.
I feel like this is something in Windows 10 or my laptop’s settings causing the issue.
I’m sure someone else has been having this issue, but searching everywhere I can’t find a solution.
Please help!
