Windows 10, Audacity V 2.0.3
I received Audacity as a gift, V 2.0.3. I connected the cassette player and installed the program. However I am not able to find the proper USB Audio Codec or Microphone USB Audio Controller options for Recording.
I uninstalled and reinstalled and it worked. However after recording, there was no sound when I played back.
Now, attempting again, I am back to my original settings with no USB options for Recording.
I am using Windows 10.
Thank you
Audacity 2.0.3 is ancient. The current version is Audacity 2.1.1 which you can get here: http://web.audacityteam.org/download/
When using a USB audio device, connect the device before you launch Audacity.
Then select the required input and output devices from the device toolbar.
You may also find some of these tutorials useful: http://manual.audacityteam.org/o/man/tutorial_copying_tapes_lps_or_minidiscs_to_cd.html
Thank you so much! I’ll try these suggestions tonight…
