Have a new Acer Aspire 5 running WIn-11 and using Audacity 3.1.3.
I moved my AUP3 (and older AUP) files onto the NTFS 1TB HDD. I know you cannot directly open from FAT or eFAT drives.
When I go to open any previous AUP3 files I get the error message “Cannot import AUP3 format. Use File>Open instead.” The files also will not open using the OPEN command. It will open (and covert) older AUP files. Also if I record a new AUP3 file, it will open that file after being saved.
I run the current Audacity on my Win8.1,WIn10, WIn 7 machines (also I use older version on Audacity on an XP machine that I use as a recording backup for my radio show). I have not had any issue transferring AUP3/AUP files between these machines.
Thoughts?
Thank you in advance - Audacity is a truly a workhorse - used by a couple of the smaller radio stations and their hosts for their shows.
Dr LAB
