I cannot record stereo. When monitoring the input I can hear stereo but stereo left and right VU meters are in exact sync and when I play back it’s on mono, i.e. both tracks are the same. Worked okay before I upgraded to 2.12.
Winodws 7 pro
AUDACITY 2.12
USB input via Yamaha audiogram 6
when monitoring a stereo LP (source) through the audio interface phone jack, I can hear it’s stereo, but Audacity records both tracks the same.
Audacity plays back multiple mono tracks to left or right okay, as designed.
Not sure what to do next. Any ideas very much appreciated.
Did you follow the instructions you were already given? If not, click this blue link. In the page that appears in your web browser, look in the green box and carry those steps out.
So, right-click over the USB Audio Codec that relates to the Yamaha (it may be called “Microphone” even thought it isn’t). Choose “Properties”, then click the “Advanced” tab. In the “Default Format” section, make sure the dropdown menu is set to a “2 channel” choice.
