Why can I see two identical lines of track when I used to only see one!
I usually import MP3 tracks and see one line of music. I pressed the multi-tool by accident and ever since I now get two identical tracks, one on top of the other. If I delete some of the track, it deletes from both. I want to work with one line of music not two, It used to do it! I’ve tried changing from stereo to mono with no luck. Please help! It’s driving me crazy!!!
Most audio files are stereo… You can check with MediaInfoOnline. It will say 1 or 2 channels.
Assuming you have opened a stereo file, you can export it as mono.
