Hi,
I am new to Audacity. Please forgive me if this is not an appropriate venue for this question.
I would like to create 10 minutes of “white” noise, but only including frequencies above 5KHz. I assume I would want some smoothing of the frequencies between say 4KHz and 5KHz rather than a totally sharp cutoff.
Can such a file be created directly, or can it only be created by filtering a full spectrum white noise signal? I have tried to create the signal by filtering, but I so far have not found a filter (or possibly a set a filter parameters) that does a good job.
Any suggestions are much appreciated.
Thanks,
John
