Which version of Audacity to use, help please
Years ago I bought a USB Cassette Converter, Model 2034, Electro Brand. I need to use it to convert 2 of my Dad’s old cassettes. Pulled everything out and I can’t find the CD with the Audacity Setup wizard. The computer being used is old. Windows 7 Pro. I found your legacy page (thank you) but wanted to check before downloading anything.
Thanks for your help. I really appreciate it.
Audacity 3.1.0 is believed to work correctly on Windows 7, 8.1 and Vista: Audacity ® | Download for Windows.
Older versions of Audacity are available here: Old Audacity versions download
Thanks for responding. I’ll try the 3.1.0. Appreciate your help.
