I’m trying to edit a track. One section was not strong enough so I use Amplify to raise it. But it leaves two steps on the wave. Please see screenshot below. Which Effect can be used to smooth the steps.
I guess there might be another effect that can smoothly amplify a section but I’m not sure if it’s available.
Thanks & regards,
Lee
The [u]Envelope Tool[/u] can be used to fade-up or fade-down parts of the program.
Or, the compressor and limiting effects tend to even-out the loudness. Both of these effects “push down” the loud parts (or peaks) and then make-up gain is normally applied to bring-up the overall loudness.
I usually edit tracks of accompaniment and recorded sax performance. Sometimes, they are not perfect so I need to make minor changes manually after having both tracks.
One more question on the Envelope Tool. It seems I cannot amplify the wave further with Envelope Tool once the little white-colored dots reach the dotted lines at top and bottom of the wave. Please see attached screenshot below. Would it be possible to amplify the wave further?
Thanks & regards,
Lee
