Where have the Macros gone?
What has happened to Macros in Audacity 4? I had a number of macros setup up in the previous version that streamlined my workflow. I can’t use version 4 without them. Have I missed something?
Macros are not in Audacity 4.0 and may get added to a future version. In the meantime, I have added macros to Soundscaper, my Audacity 4 port to the web. You should be able to import your existing Audacity 3 macros there.
Yes, this is a big problem! I have worked hard on my macro so I can get through a lot of voiceover auditions in one day. I won’t upgrade to Audacity 4 until they support macros and can import them from Audacity 3. Please expedite that feature.
It seems this is in the pipeline for 4.1.
Thank you!! I’ll keep using v 3 until then.
