everytime i hit pause or stop, it starts playing from the beginning!
Probably not. When you Spacebar Stop, it starts from the beginning, but then you P Pause, it stops dead and picks up right from there. Also anytime you click in the timeline, a new stop point is established. Click half-way down and Spacebar Stop will return to that point. I rarely use the P Pause key. I magnify and drag-select to play a segment.
I’m having the same issue! Used to be able to pause it and it would restart where you pause it at. Now it restarts from the beginning. Something is wrong. And I don’t see any fix to it.
No worries at all, Jayme—we’ve all been there! Try using the spacebar to pause and resume playback instead of hitting stop. That usually continues from the same spot. You’ve got this—learning new software takes time, and asking questions is how we all get better.
