When exporting the original file exports instead of the edited one
Hi hoping this is an easy fix I’m new to audacity so probably soemthing obvious. I’ve made alterations to my track, you can clearly hear it and see the change in waveform. I’ve saved these changes successfully as they are still there when I reopen the project but when I goto export the file none of these alterations are kept and its just exporting the original audio. Any help with this would be greatly appreciated.
May I suggest exporting it to a unique(different) file name and see if you still have the same issue.
If the source file is on the desktop, Windows may not allow you to replace it depending on your permissions
Ensure you’re exporting the correct edited track in Audacity. Double-check your export settings to include the changes you made. If issues persist, seeking more specific help might be beneficial. Good luck!
