“Host” can refer to any of a number of things, for example:
- A person who provides hospitality
- Host or sacramental bread
- Host (biology) — organism harboring another organism on or in itself
- Host (psychology) — “personality” emphasized in treating dissociative identity disorder
- Host (radio), the presenter or announcer on a radio show
- Host, (sometimes hostess, in feminine form) — the presenter for an event
- Host, headwaiter (Maître d’ or Maître d’hôtel) of a restaurant or hotel
- Host (network), a computer connected to the Internet or another IP based network
- Terminal host — a multi-user computer or software providing services to computer terminals, or a computer that provides services to smaller or less capable devices.
- Virtual machine host — a computer within which another computer is emulated and hosted by virtualization
- Cossack host — was the administrative subdivision of Cossacks in Imperial Russia based on their location.
- Furious Host or the Wild Hunt — a European folk myth
- Heavenly host, an “army” of good angels in Heaven
Host - Wikipedia
In music/audio software, a “Host Program” or “Host Application” will usually refer to a “VST Host” application, though really the term “VST host” should be used to avoid confusion.
As an Audacity user you will be aware that there are other types of audio plug-ins as well as VST plug-ins. The most common types of audio plug-ins are (in no particular order); VST, LADSPA, Nyquist, DirectX, AudioUnits and RTAS plug-ins. Of these, VST is by far the most widely known, to the extent that many audio software users will equate “plug-in” with “VST” (very successful marketing by Steinberg).
“the books” ??? Any particular books?
Audio recording, acoustics, sound design, music, digital audio… are all huge subject areas that can be studied far beyond bachelor’s degree level. Some books will be aimed at a high level and will be mostly incomprehensible to anyone that has not already done a great deal of study. There will be others that are aimed at an introductory level. It’s the same with other subjects.
“Mortimer Rhind-Tutt: Music Technology From Scratch” is often recommended (though I’ve not read it myself) as a good introduction to “music technology” and may be available through your local library.
Rewire and VAC perform a similar task of joining audio applications together with “virtual audio cables”, but approach the task in different ways. Possibly one of the most important differences is that VAC creates routes using the standard inputs and outputs of Windows audio applications, whereas Rewire makes connections between a “Rewire Host” application (there’s that word again) and one or more “Rewire Client” applications. To use Rewire, the applications must specifically have Rewire support built in.
The other major difference is that VAC is an “application” (program), whereas Rewire is a “protocol” (a standardised method of transfering data/information). Applications that support Rewire can communicate with each other without the need of a third party application (such as VAC). Rewire is built into many of the more advanced commercial audio programs and is aimed at the professional/semi-professional market. VAC is aimed more at the audio enthusiast and can be used with (Windows) applications that do not support Rewire.
Rewire provides a similar functionality to “Jack” on Linux computers. http://jackaudio.org/documentation
