What has happened to loudspeaker recording?
Hi!
I would like to flag a new recording bug that has emerged with one of the most recent updates to Audacity because this didn’t use to be an issue before. Audacity has begun skipping/omitting sound when it comes through loudspeakers, such as a microphone or a phone or laptop loudspeaker. Meaning it doesn’t get recorded or at least not properly. Anyone experiencing the same issue?
Has some kind of a new feature been introduced to “fix” an echo or the metallic rattle that loudspeakers and microphones give? This is proving very very counterproductive, because I can no longer rely on Audacity to record and transcribe speech. It’s just omitting and skipping too many words and the transcriptions become nonsensical.
If there’s a setting or a quick fix that can solve this, I’d be very grateful to hear! thanks in advance for any tips.
https://manual.audacityteam.org/man/faq_recording_troubleshooting.html#How_can_I_record_without_small_skips_dropouts_or_duplications
Plan-B: revert to a previous version of Audacity … Old Audacity versions download
Plan-C : use free recording software which uses all the cores of your computer, so less likely to hiccup.
Assuming you are on Windows, make sure Windows “Enhancements” are turned OFF. .
