In latest 3.4 what happened to option to export selected audio as?
Used to be easily accessible under FILE…???
I’m going to install 3.4.0 and look, but I strongly suspect this is a patch to a long-running problem. Export just exports what you select. If you don’t select anything, it exports the whole show.
I have personally selected a portion of my show and then picked Export rather than Export Selected. Sometimes hours later I figure out my exported show is wrong.
Try it on a simple sound test. Select something tiny and do a straight File > Export. I bet you get the tiny portion. This is how many other “normal” programs work.
It got moved into File > Export Audio together with the other options
