What drive should be the temp drive?
Opening files takes ages - what drive should the Temp folder be in please?
Audacity only has one drive, the C:\ if you’re on Windows. The new Audacity version will save Projects on audio.com.
That’s it. Audacity doesn’t much like External, Network, Internet, and Cloud drives. You can use those drives but you should shut Audacity down first. Bring external work back to C:\ and then open Audacity.
