What as an active user does not suit me in Audacity 4?
  1. Keyboard combinations often lose focus, do not react (even with the desired language layout!)
    (it is decided so far that just click on the tab “main” then back to “project.”
    2. To reproduce the selection and play the entire audio clip used to be convenient (in version No. 3) with one “space” key. Now it is not possible to assign a gap for all types of playbacks. Please return as it was or add the possibility as an exception, without errors in the program to assign one key to all types of playbacks.
    3. Visualization of tracks: Why can’t you adjust the view of the track visualization once, and not adjust it every time again from the project to the project?
    4. The allocation of the segment why is always dropped after applying the effect to it?!
    5. And please add a separate option that will clear the action history from the project and overwrite “smart clips” in “baked form” (as they are cropped) (to save disk space)
Thank you for your attention and for the work of a multi-respected team of developers!
