Website: Download button doesn't work
in Download page the DOWNLOAD BUTTON simply do nothing, no prompt, no message, no popup, just nothing, the only thing that works is CONTINUE to signup for CLOUD SAVING. here is the download page Audacity ® | post-download. if not activated via BUTTON CLICK or LINK it should be activated using a SCRIPT, but in this case there is none. so sorry to say that you are forced to click CONTINUE.
The Cloud rubbish is optional.
If you want do download the latest version for your operating system, just go to the website www.audacityteam.org, and look at the button “Download Audacity 3.7.0” (or whatever is current when you are there). Do not click that button, but below it in smaller letters: “Download without Muse Hub” - klick there.
If it does not download, your computer settings may prevent it.
When you click any download button on the page, the download starts and after a small delay, you get redirected to the “post-download” page. The post-download page itself does not contain any downloads. If you have cancelled the download, you can start a new one by navigating to the homepage or one of the downloads pages.
Yes I am in the same position. Using a Windows 11 laptop, I want to download Audacity 3.7 but as dhany says, nothing happens at all. It really needs sorting out. There is no message, no failure, nothing is blocked. I will just have to use something else, regrettably.
This topic was automatically closed after 29 days. New replies are no longer allowed.
