I’m running into all sorts of nuisances with waveform navigation in this rel4. This is my 1st entry on it! - there’s no obvious method of deselecet . If I run the trackpad across a section of waveform to select/highlight it, but then want to clear it, or if I did a bad key combo while doing it like holding option down at the same time causing a window to pop up, I just want to select somewhere off the waveform to clear/cancel what I was doing and deselect everything. But in rel4, punching somewhere off the waveform - the obvious place being down bellow the waveforn - the playhead moves that spot instead. It’s messing me up. Rel3 didn’t do this. Restore the rel3 quality of waveform navigation.
Also, in rel3, the playhead was tied to the selection. Or at lease when you hit play it was tied to the section of track that was highlighted. I don’t even know here whether to say “selected” or “highlighted” anymore because it’s so nonobvious. But apparently it’s a separate thing now. Another huge nuisance. What are ya’ll thinking when you did these changes. This would be my #2 entry but I wanted to include it here. - highlighted vs selected vs playhead position.
