Until today Exports set at .wav 4100 were 1411Kbps. for some reason on the same settings it exports now at 2116. The Quality sample rate was on Lowest I tried it on medium still 2116. I upgraded my version to the current one still the same problem.I have read through several suggestions in previous posts and checked I am set on 4100 and 16 bit.
Running win10 and 3. 0. 2.
How are you checking/confirming that?
What format are you exporting to? WAV? FLAC? Etc.?
Uncompressed 44,100Hz (44.1kHz) x 16 bits x 2 channels = 1411kbps.
Perhaps you’ve change the “encoding” from 16-bit to 24-bit. See: WAV Export Options - Audacity Manual
Thanks Sorry for the delay never got an OK on approval. Now sorted I did nothing other than upgrade but for some reason in the Export box the encoding had changed. Now sorted Thanks
