When I create a WAV or MP3 file and try to play it in Windows Media Player, I receive the following error message:
Windows Media Player cannot play the file. The Player might not support the file type or might not support the codec that was used to compress the file.
I’m using the default settings of Audacity 2.0.3 (from the exe installer). The files will play in Quicktime Player.
