I’m trying to record using Windows DirectSound and Stereo Mix (Realtek (R) Audio). The VU meter is moving just fine, showing that Audacity is receiving the audio, but when I click record the audio track it’s just a flatline - no recording. How do I get it to record?
Windows 11
Audacity 3.2.1
What are the levels on your meters? Is the playback volume turned-up? If you are around -30dB or lower the waveform will look pretty-much like a flat line.
…That’s the only thing I can think of because you’re right… If the recording meters are moving it means the audio is getting into Audacity.
(Un-)check Transport > Transport Options > Sound Activated Recording.
