Try pressing Windows Start, Power button then restart (not shut down).
Does the problem go away if you disable Oldskool in Plug-in Manager or don’t use the plugin?
If not, you may want to test your computer memory for errors :
How to Test RAM with Windows Memory Diagnostic Tool.
