Audacity recognises the .dll file for Voxengo CurveEQ - and a bunch of Kontakt 5 stuff - but none of them appear on the effects drop-down. Where am I going wrong here?
Foreign effects appear in the second segment of the effects list. It goes A-Z twice.
Kozikowski, many thanks. Under the line, right? Lot of stuff there but sadly not CurveEQ or Kontakt 5.
If you have a question please give us the necessary information from the pink panel at the top of the page.
Curve EQ will appear and work in the current Audacity 2.1.0 from http://web.audacityteam.org/download/windows if you install CurveEQ in one of these locations: http://manual.audacityteam.org/o/man/effect_menu.html#syslocs. You must install the 32-bit VST 2 version even if you have a 64-bit computer.
Audacity does not load VST synths or instruments.
