Ciao a tutti… perché quando esporto un file audio in mp3 , con l’iPhone si sente basso..Il file audio è una traccia di una registrazione con basso elettrico.
Il suono della traccia con le cuffie o ampli si sente bene.quando esporto no.
I can think of two possibilities -
The tiny phone speaker can’t reproduce bass (plus the phone may filter-out low frequencies before they get to the speaker).
Your connection was “wrong” and you recorded mono as stereo with the left & right out-of-phase. When left & right are mixed for the mono speaker they cancel-out.
The solution for that is to Split Stereo Track so you can edit left & right separately. Then click the little “X” to the left of the waveform to kill one of them. Export as mono and it will play through both speakers.
…If you use a pro microphone with a balanced XLR connection with a “simple adapter” and plug it into a stereo mic input on a computer, the balanced signal becomes two opposite-phase unbalanced connections.
