Is it possible to record audio from VoicemodV3 and import it to Audacity? If anyone is familiar with Voicemod, I would like to know if I can record straight to Audacity from the Voicemod app. Google says it’s possible, but I can’t figure it out.
I don’t know anything about VoicemodV3 but you can generally record whatever is coming out of your Soundcard… Recording Desktop Audio.
Thank you.
If your cell phone has a headphone jack (something that is increasingly unlikely), you may be able to connect it to a mixer and run the voicemod app on your phone.
Yes, it is possible. In Voicemod V3, you can use the voice changer on your microphone input to create audio, and then record that input in Audacity. For this, you need to select the ‘Voicemod Virtual Audio Device’ as the input device in Audacity. After that, your voice-changed audio from Voicemod will be recorded directly.
Nice! Thank you.
Thank you.
