I had a go at voice editing and failed miserably, does anyone know a way to make a voice sound more metallic or robot like?
I uploaded an attachment with a voice from a tv show both normal and then manipulated. Are there any effects I could use to change the regular voice into the masked/edited one. (that didn’t make a lot of sense but listening to the attachment might) Audio.zip (230 KB)
The three effects that spring to mind are Pitch Shift (which Audacity calls Change Pitch), Vocoder, and Ring Modulator. Audacity doesn’t offer the last two effects (which are likely to be much more useful than Pitch Shift).
That’s because technically, you’re not editing. You’re performing special effects. I started reading this wondering who was having troubles deleting words and moving sentences around. That’s pretty straightforward stuff.
