I am running Audacity 2.1.1 on windows 10. I don’t see vocal remover in the EFFECT tab. I did see them in the manage tab under the sub menu of EFFECT but even after enabling it. It does not show in the menu. Please Help…
Moderator note: Please do not piggy-back on another user’s thread when your issue is different - I have split your pots off and given it a more appropriate title.
There is no need to use Vocal Remover. If you need the dual mono output that Vocal Remover produces, use Vocal Reduction and Isolation instead, and choose the “Remove Center Classic (Mono)” choice. See Vocal Reduction and Isolation - Audacity Manual.
Vocal Reduction and Isolation is usually much preferable to Vocal Remover, assuming you want a stereo result.
Moderator note: > Please do not piggy-back on another user’s thread when your issue is different - I have split your pots off and given it a more appropriate title.
One reason for starting a new topic from your point of view is that we look first for unanswered topics.
So if you jump on someone else’s topic you will probably get a slower response.
