I’m an old newbie trying to find a way to add a visual 2 bar count in before an Audacity track.
Any help would be much appreciated.
Audacity does have a metronome generator … Rhythm Track - Audacity Manual
Thank you Trebor
I’m probably asking the impossible here.
There’s a few visual metronomes available on line, like M1 where it shows a clear visual count in.
I would like to put 2 of these bars before the Audacity track kicks in.
Thanks again
The metronome (rhythm) track will make the output meter move. It can be moved & resized …
I had the same need to record myself, and I simply added a 2-bar audio click manually at the beginning of the track. Not really visual in Audacity, but it helps me get started in rhythm. Otherwise, I use an external metronome for the visual.
