Version mismatch
We have installed V3.7.5 from the below link, but it is showing the lower version( 2.5.1 )after installation, Can you please help us with this.
Link - https://www.audacityteam.org/
You might have two version installed and the older one may be a 32-version.
If you are on Windows the 64-bit version will be in:
C:\Program Files\Audacity
The 32-bit version will be in:
C:\Program Files (x86)\Audacity
