VB-audio virtual cable
Hello everyone!
I would like to record sound from youtube video via VB - audio virtual cable. I have the driver already installed. Yesterday i managed to get a nice recording using the cable however today it’s not working properly. I get a vibrating, resonating sound.
Any ideas what could have gone wrong?
Thank you very much!
You don’t need virtual audio cable to record YouTube with Audacity …
https://manual.audacityteam.org/man/tutorial_recording_computer_playback_on_windows.html
[WASAPI works for me].
I’ve never used VAC so just a guess, but make sure Audible Input Monitoring it turned OFF. It can sometimes create an internal feedback loop.
It worked for me to! Tkank you!
It is turned off. I guess the problem lies elsewhere…
Luckily some other method was found and I don’t need the cable anymore…
Thank you to both of you!
