V 3.6.1 envelope tool
Envelope tool is erratic. I use the tool to adjust the amplitude, then when I switch back to the selection tool the displayed waveform does not reflect the envelop adjustment I just made, although it sounds like the adjstment was made.
That sounds like this bug: Incorrect waveform appearance when Envelope applied to clip offset from zero · Issue #6927 · audacity/audacity · GitHub
It should be fixed in the next release.
I am impatiently waiting for the next release because this bug severley impedes my ability to put together synadicated pre-recorded music shows where I need to segway between numbers and do voiceovers.
