V 3.1.3 Can't record to a new track
Hi,
I have just installed the newest Audacity (3.1.3) and I have often used Audacity to record several tracks separately while the existing tracks are on mute. And then combine them later.
When I try that in the new version, I find it adds it on the end of the existing track.
Before, it has always recorded the new audio on its own new track from the beginning.
So I made a new empty track, and put the cursor at the start. Then I tried to mute the existing track, but that just made the new track “Solo” and it wouldn’t record.
How do I do it please?
The only way I can see is to combine several Audacity files. There MUST be an easier way!??
Update:
It now won’t record at all, even on the same track. (I really wish I hadn’t upgraded it :frowning: )
Thank you
Since it was recording before, Tools > Reset Configuration is likely to restore this ability.
Try: Edit > Preferences > Recording > Record on a new track
Thank you Jademan, you are fabulous!
:smiley: :sunglasses:
