Now the bad news : with those settings processing time is ~3x playback time. (~3min to process 1min).
The thuds (~200Hz) will require a second pass with different settings.
I’m inclined to think that declicking should be done before compression, otherwise it becomes very loud.
On what basis did you choose these parameters? For example, click length. The spectrogram shows that a click lasts about 60 ms. Or is this a parameter specifically for the attack?
Thank you!
Oh.. I talked about all the wave..
I’m just a beginner at this
2 passes don’t clear all, I’ve tried 4 and it getting better (time x3x2..). This settings I found for thuds:
What about time. I was right, de-clicking must be done before compression. I’ve used it at raw recording and this (high clicks, 1 pass and 12 bands) was enough. About ~x0.9 playback time.
The thuds are ~60ms long. Step size X maximum click length = 60 ms for thuds.
