Update Build Instructions for Windows, perhaps?
Hello,
The build.txt that is on the repo says you have to use Python 2.7 to build Audacity. But it looks like all python 2 scripts has been updated to python3. Am I right? In that case, the instructions on build.txt might needed to be updated.
Looking foward to 3.0 release!
Thanks!
Rafa
Yes you’re correct on both points. Audacity has been updated to Python 3 and the instructions need updating.
The instructions are earmarked for an update.
See this pull request for updated build.txt instructions: https://github.com/audacity/audacity/pull/745
Please report back on how well this works.
I hope this helps. :smiley:
Here is the proposed complete build.txt (there may be 1 warning “Jack” in Cmake which is OK):
Instructions for building on Windows.
Fuller instructions that include
   * Installing CMake
   * Portable Settings
   * Building an Installer
can be found on our wiki at http://wiki.audacityteam.org/wiki/Building_On_Windows (not updated yet)
1. MSVC 2019: Download and install Microsoft Visual Studio 2019
  https://visualstudio.microsoft.com/thank-you-downloading-visual-studio/?sku=Community&rel=16
  be sure to include the Desktop Development with C++ Workflow
  this build was testing using VS 16.8.5
2. Git: Download and install Git, for example by installing:
  Git for Windows: https://git-scm.com/download/win
  and optionally GitExtensions: http://gitextensions.github.io/
  download and run the .msi installer.  GitExtensions has a GUI interface, includes Git for
  Windows and has a Git bash command line in the bottom panel of the screen.
3. Python
  We no longer use Python 2.7.18 during the build. Instead we must use Python 3.
  You can download Python 3.9.1 from https://www.python.org/downloads/windows/
  Select the Python 3.9.1 Windows Installer (32-bit)
4. wxWidgets:
 a) Clone wxWidgets and checkout 3.1.3 from the Audacity fork of the
    wxWidgets project:
       https://github.com/audacity/wxWidgets/
    for example, in the git-bash command line
      mkdir wxWidgets
      git clone --recurse-submodules https://github.com/audacity/wxWidgets/
    IF you forgot the --recurse-submodules, you can correct that later by:
      git submodule update --init
    It is instructive to review but do NOT follow the instructions for building at
    https://github.com/audacity/wxWidgets/blob/audacity-fixes-3.1.3/README-GIT.md
    https://github.com/audacity/wxWidgets/blob/audacity-fixes-3.1.3/docs/msw/install.md
 b) We (currently) build the 32 bit DLL version,
    and Audacity is built 32 bit too.
    Set WXWIN environment variable to the appropriate directory where you installed
    wxWidgets. This will tell CMake where to find wxWidgets later.
    To set WXWIN, click on Settings (the cogwheel icon from the start menu)
    Then in the 'find a setting' search box type 'env'.
    Choose 'Edit the system environment variables'
    Then the 'Environment Variables' button
    Then in system variables, for variable and value,  add (for example)
    ==> WXWIN         C:\aud300\wxWidgets
    You will be building a dll version with MSVC2019 IDE, so...
	==> In Windows File Manager, right-click on ../wxWidgets/build/msw/wx_vc16.sln,
	==> select Visual Studio 2019,
	==> in the solutions configurations drop-down list, change "Debug" to "DLL Release",
	==> then select Build > Build Solution.
	When the build completed, you will get the message:
	========= Build: 24 succeeded, 0 failed, 0 up-to-date, 0 skipped ============
	Close Visuual Studio.
5. Audacity
 a) Clone Audacity from the Audacity GitHub project.
      mkdir audacity
      git clone https://github.com/audacity/audacity/
 b) Open the CMake GUI
     ==> Open VS 2019 > "continue without code" > File > Open > CMake
     ==> Open CMakeLists.txt in root of audacity source folder you cloned
	 ==> Wait for the CMake Overview Pages tab to appear (be patient)
	 ==> Click "Open the CMake Settings Editor" in this new tab
	 ==> Scroll up to the top of the window and settings
	 ==> In the Configurations window, click the green "+", then select x86-Release
	 ==> Set Configuration type: Release
	 ==> Verify Toolset: msvc_86
	 ==> Keep Build Root: ${projectDir}\out\build\${name} (default, you can change it)
	     (this corresponds to CMAKE_BINARY_DIR)
     ==> Click on "Show advanced settings" (scroll down).
	 ==> Change CMake generator: VS 16 2019 (was Ninja)
	 ==> Click "Save and Generate CMake cache to load variables" once, then
	 ==> Click "Save and Generate CMake cache to load variables" a second time
	     or select Project > Generate CMake Cache
  c) Switch to the Ouput tab
     ==> Wait for "CMake generation finished".
	 ==> Check the Error List window:
	     you should have 0 Errors and 0 Warnings.
  d) Return to the CMakeSettings.json window
     ==> Review CMake variables and cache
	 ==> Note that:
	 wxWidgets_LIB_DIR > 'C:/aud300/wxWidgets/lib/vc_dll' (your path may be slightly different)
  e) Build
     ==> Select Build > Build All
     ==> Click on the Output tab and wait for the message "Build All succeeded"
	 ==> Check the Error List tab.  There should be 0 Errors and 17 Warnings.
     ==> Check the output directory indicated in step 6 to find `../bin/Release/Audacity.exe`
Thank you jademan. Sorry to not check the PR tab on git before asking… :blush:
Let me try the new instruction. It took me two days to be able to compile using the previous one. (I’m forcing myself to understand more C++)
On question: I moved thad setup.h file from msvc/wx to include/wx. Is this still needed? It appears on wxWidgets instruction.
https://github.com/audacity/wxWidgets/blob/audacity-fixes-3.1.3/docs/msw/install.md#installation---------------------------msw_install
I’m going to remove all I have from Audacity and try to compile it again following the new instruction. Then I’ll give a feedback.
Thank you,
Rafa
It worked like a charm! Like we say here on Brazil: It was as simple as life should be :laughing:
Indeed it gave the warning you mention. Is it something that should be fixed? Or can I just ignore it?
Other thing: I just realised that if I want to debug Audacity using Debug configuration I need to build wxWidgets “DLL Debug” first. It might sounds logic… but for me it wasn’t. So MAYBE it would be nice if the instruction includes something about this.
Thanks,
Rafa
Good, I think the old instructions are a rite of passage thing. They assume that you’ve done this before a hundred or so times, that you already have a working build, and that you can deal with the new errors as they crop up. :wink:
Yes, no need to move setup.h for Windows.
Ignore the warning. It’s just a case conversion issue that I believe is OS dependent. The full PR gets rid of the warning.
:smiley: Glad to hear that the instructions are working well for you. :smiley:
Why not work this out then post another pull request ? It might be simple. :wink:
Why not work this out then post another pull request ? It might be simple. > :wink:
Sure! That will be my first PR on an open source project. So it might get it wrong in something.
I will wait your PR gets approved then I will send mine.
Rafa
:laughing:
Hey jademan,
How about I writing here what I have in mind and then, if you agree, you can incorporate to your PR? It might be simpler, I don’t know. Again, this is my first time trying to contribute to an open source program…
It added between /**/ what I was thinking. This is just an idea.
   * Installing CMake
   * Portable Settings
3. Python
4. wxWidgets:
    wxWidgets project:
      mkdir wxWidgets
	Additionally, if you want to later debug Audacity, you have to build wxWidgets Debug dll.
	==> in the solutions configurations drop-down list, change "DLL Release" to "DLL Debug",
	Close Visual Studio.
5. Audacity
      mkdir audacity
	 ==> Note that:
  e) Build
  f) Build Debug Version
     If you want to do further developments on Audacity you will need to build the Debug version
     You can use the same instructions above (Steps 'a' to 'e') but changing to this configurations on step 'b':
     ==>  In the Configurations window, click the green "+", then select x86-Debug instead of x86-Release
     ==> Set Configuration type: Debug instead of Release
     Then check the output directory to find the Audacity solution. Probably 'C:/aud300/out/'
Thanks. I am glad you got this working. Your comments will be helpful to other current and future contributors.
And I am sure James will read them, as well. :smiley:
Odd. The instructions worked worked for my installation of Visual Studio 2019 version 16.3.8. Using the same instructions starting with a new Virtualbox Windows 10 installation with the latest Visual Studio 2019 version 16.9.0 did not work with 68 errors. I am a novice Visual Studio user. Not sure what went wrong.
Severity	Code	Description	Project	File	Line	Suppression State
Error	C3536	'playbackBufferSize': cannot be used before it is initialized 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\AudioIO.cpp	1914
Error	C2672	'std::min': no matching overloaded function found 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\AudioIO.cpp	1914
Error	C2780	'_Ty std::min(std::initializer_list<_Elem>)': expects 1 arguments - 2 provided 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\AudioIO.cpp	1914
Error	C2784	'_Ty std::min(std::initializer_list<_Elem>,_Pr)': could not deduce template argument for 'std::initializer_list<_Elem>' from 'size_t' 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\AudioIO.cpp	1914
Error	C2782	'const _Ty &std::min(const _Ty &,const _Ty &) noexcept(<expr>)': template parameter '_Ty' is ambiguous 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\AudioIO.cpp	1914
Error	C2784	'const _Ty &std::min(const _Ty &,const _Ty &) noexcept(<expr>)': could not deduce template argument for 'const _Ty &' from 'int' 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\AudioIO.cpp	1914
Error	C2780	'const _Ty &std::min(const _Ty &,const _Ty &,_Pr) noexcept(<expr>)': expects 3 arguments - 2 provided 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\AudioIO.cpp	1914
Error	C2264	'lrint': error in function definition or declaration; function not called 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\AudioIO.cpp	2006
Error	C3536	'playbackBufferSize': cannot be used before it is initialized 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\AudioIO.cpp	2007
Error	C2264	'lrint': error in function definition or declaration; function not called 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\AudioIO.cpp	3006
Error	C2169	'lrint': intrinsic function, cannot be defined (compiling source file C:\audacity300\audacity\src\Dither.cpp) 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\float_cast.h	61
Error	C2169	'lrintf': intrinsic function, cannot be defined (compiling source file C:\audacity300\audacity\src\Dither.cpp) 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\float_cast.h	73
Error	C2065	'lrintf': undeclared identifier 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\Dither.cpp	332
Error	C2568	'=': unable to resolve function overload 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\Dither.cpp	332
Error	C2065	'lrintf': undeclared identifier 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\Dither.cpp	335
Error	C2568	'=': unable to resolve function overload 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\Dither.cpp	335
Error	C2065	'lrintf': undeclared identifier 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\Dither.cpp	339
Error	C2568	'=': unable to resolve function overload 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\Dither.cpp	339
Error	C2065	'lrintf': undeclared identifier 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\Dither.cpp	343
Error	C2568	'=': unable to resolve function overload 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\Dither.cpp	343
Error	C2065	'lrintf': undeclared identifier 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\Dither.cpp	395
Error	C2568	'-': unable to resolve function overload 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\Dither.cpp	395
Error	C2169	'lrint': intrinsic function, cannot be defined (compiling source file C:\audacity300\audacity\src\Mix.cpp) 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\float_cast.h	61
Error	C2169	'lrintf': intrinsic function, cannot be defined (compiling source file C:\audacity300\audacity\src\Mix.cpp) 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\float_cast.h	73
Error	C2169	'lrint': intrinsic function, cannot be defined (compiling source file C:\audacity300\audacity\src\TrackPanel.cpp) 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\float_cast.h	61
Error	C2169	'lrintf': intrinsic function, cannot be defined (compiling source file C:\audacity300\audacity\src\TrackPanel.cpp) 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\float_cast.h	73
Error	C2169	'lrint': intrinsic function, cannot be defined (compiling source file C:\audacity300\audacity\src\WaveTrack.cpp) 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\float_cast.h	61
Error	C2169	'lrintf': intrinsic function, cannot be defined (compiling source file C:\audacity300\audacity\src\WaveTrack.cpp) 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\float_cast.h	73
Error	C2264	'lrint': error in function definition or declaration; function not called 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\WaveTrack.cpp	1634
Error	C2169	'lrint': intrinsic function, cannot be defined (compiling source file C:\audacity300\audacity\src\effects\Compressor.cpp) 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\float_cast.h	61
Error	C2169	'lrintf': intrinsic function, cannot be defined (compiling source file C:\audacity300\audacity\src\effects\Compressor.cpp) 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\float_cast.h	73
Error	C2264	'lrint': error in function definition or declaration; function not called 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\effects\Compressor.cpp	364
Error	C2264	'lrint': error in function definition or declaration; function not called 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\effects\Compressor.cpp	365
Error	C2264	'lrint': error in function definition or declaration; function not called 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\effects\Compressor.cpp	366
Error	C2264	'lrint': error in function definition or declaration; function not called 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\effects\Compressor.cpp	367
Error	C2264	'lrint': error in function definition or declaration; function not called 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\effects\Compressor.cpp	368
Error	C2264	'lrint': error in function definition or declaration; function not called 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\effects\Compressor.cpp	771
Error	C2264	'lrint': error in function definition or declaration; function not called 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\effects\Compressor.cpp	772
Error	C2264	'lrint': error in function definition or declaration; function not called 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\effects\Compressor.cpp	775
Error	C2169	'lrint': intrinsic function, cannot be defined (compiling source file C:\audacity300\audacity\src\effects\Equalization.cpp) 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\float_cast.h	61
Error	C2169	'lrintf': intrinsic function, cannot be defined (compiling source file C:\audacity300\audacity\src\effects\Equalization.cpp) 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\float_cast.h	73
Error	C2264	'lrint': error in function definition or declaration; function not called 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\effects\Equalization.cpp	2473
Error	C2264	'lrint': error in function definition or declaration; function not called 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\effects\Equalization.cpp	3194
Error	C2169	'lrint': intrinsic function, cannot be defined (compiling source file C:\audacity300\audacity\src\export\ExportCL.cpp) 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\float_cast.h	61
Error	C2169	'lrintf': intrinsic function, cannot be defined (compiling source file C:\audacity300\audacity\src\export\ExportCL.cpp) 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\float_cast.h	73
Error	C2264	'lrint': error in function definition or declaration; function not called 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\export\ExportCL.cpp	399
Error	C2264	'lrint': error in function definition or declaration; function not called 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\export\ExportCL.cpp	401
Error	C2169	'lrint': intrinsic function, cannot be defined (compiling source file C:\audacity300\audacity\src\export\ExportMP3.cpp) 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\float_cast.h	61
Error	C2169	'lrintf': intrinsic function, cannot be defined (compiling source file C:\audacity300\audacity\src\export\ExportMP3.cpp) 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\float_cast.h	73
Error	C2264	'lrint': error in function definition or declaration; function not called 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\export\ExportMP3.cpp	1752
Error	C2169	'lrint': intrinsic function, cannot be defined (compiling source file C:\audacity300\audacity\src\export\ExportFLAC.cpp) 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\float_cast.h	61
Error	C2169	'lrintf': intrinsic function, cannot be defined (compiling source file C:\audacity300\audacity\src\export\ExportFLAC.cpp) 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\float_cast.h	73
Error	C2264	'lrint': error in function definition or declaration; function not called 	C:\audacity300\audacity\out\build\x86-Release\audacity	C:\audacity300\audacity\src\export\ExportFLAC.cpp	278
I get 68/69 errors too with the latest update.
The hazards and rewards of updating your Microsoft software. :wink:
I’ll take a look at this and see what I can find. Anyone else ?
OK, it appears that Visual Studio 2019 version 16.9.0 is now supplying intrinsic implementations for the lrint and lrintf instructions. Since VS2019 wasn’t before, Audacity was supplying it’s own version. Microsoft considers this a “fix” for a previous omission. Unfortunately, this “fix” breaks Audacity.
There is existing logic within the audacity code intended to ferret out which compilers have lrint and which ones do not, but this logic apparently needs to be adjusted.
A quick and dirty fix would be to comment out the code in float_cast where these are defined. A better solution would be to integrate into the existing inclusion logic.
Later…
So I have a fix for the 16.9.0 version of VS2019:
Edit your local copy of c:\aud300\audacity\src\float_cast.h:
  1. Add the following line immediately before the “__inline long int” line near line 59/60:
#if 0
  1. Add the following line immediate before the “__inline long long int” line near line 83:
#endif
Let me know how this works.
Thanks. I did something similar to comment that part of code out.
I also added ASIO support by copying the ASIO SDK a creating/setting the ASIOSDK_DIR environment variable to it.
I was trying to update to use newer ffmpeg import/export libraries (i.e. avformat-.dll, avutil-.dll, avcodec-*.dll) but wasn’t successful. I read somewhere else that replacing the header files in …\audacity\lib-src\ffmpeg with ones from a newer ffmpeg release would work. Doing so does make the prompt for the ffmpeg libraries use the newer dll filenames but they don’t load.
After 4 days, trying various sources, I have finally successfully built Audacity. As a first-timer, it was very frustrating. However, in the process, I learnt a little about GitHub Actions (idek how xD), CMake and MinGW.
I also got 68 errors, which I intuitively figured to comment out, so I’m glad I’ve learnt something. Thanks a lot to @jademan
Now, I just have to figure out what to do next :stuck_out_tongue:
With these edits, Audacity 3 successfully builds on latest VS with “O Errors/17 Warnings”. Thanks.
Thanks for the word. BTW, the current 3.0.1 alpha has a improved fix for this latest issue with Visual Studio 16.9. It may run a little faster… :smiley:
The build instructions work, can confirm. Just got this built here.
The person posting above my reply suggesting additional “building debug version instructions” seem good and I think that instructions to debug from Visual Studio would be good. I had suggested some in the other thread above this.
Reproduced here briefly:
Debugging Audacity
  1. Make sure it built first and check the output directory contains the exe.
  2. Select the Startup Item
    (show image)
  3. Debug >Start Debugging (F5)
Also perhaps helpful is this image showing that it seems you need to set the cmake debug/x64 and the visual studio debug/x64 profile separately or you won’t get your build.
https://i.ibb.co/BnrTkqr/same-same-matchy-matchy.png
