Recording from internet and I hear music perfectly. as soon as I hit record I get a reverb. I have not seleced any effects. When I hit pause…reverb remains…when I hit stop it immediately goes away. What setting is causing this?
Windows, right?
It’s really easy to get multiple pathways running on a Windows machine and having too many pathways open in Audacity doesn’t help much.
Assume you’ve followed all the instruction in the wiki page…
http://wiki.audacityteam.org/wiki/Recording_audio_playing_on_the_computer
You can, as an experiment, go into Audacity preferences and deselect “Play Track While Recording New Ones,” “Hardware Playthrough,” and “Software Playthrough.” Restart Audacity and make a recording. You may not be able to hear what you’re doing, but the red recording meters will bounce, you’ll get a recording, and it should be missing the echoes.
It’s not really reverb, right? It’s echoes?
On Windows “Software Playthrough” should be OFF.
Yes…it worked. it’s funny … I tried removing overdub and didn’t try removing software play though. I am new to audacity…Thanks!
