Hi there,
I have recordings of air pulses and I need to find a way to automatically determine the number of pulses per second. Typically they are in the range of 5-20 Hz. So far I have been able to do this manually.
Here is my manual workflow:
- 1kHz high pass filter (48dB rolloff)
- 3kHz low pass filter (48dB rolloff)
- Amplify until I get clipping during the pulse but not in between pulses
- Noise Gate to silence audio in between pulses (-100dB level reduction, gate threshold -6dB, attach/decay 10ms)
- Run a modified version of bpm_count.ny to calculate the air pulse frequency in [Hz]
Here is an example of what the final waveform looks like:
Instead of step #5, I would like to be able to export the peaks and their corresponding time to a text file and analyze it in Excel. Something like this:
Is this possible using Audacity/Nyquist? Could someone point me in the right direction?
Thanks,
