My computer started acting strange on the very night I installed Audacity and used it. So, as a means to troubleshoot I want to try uninstalling Audacity. However, the Windows10 “Uninstall a program” function in the Control Panel does not “see” Audacity in the list of programs from which to choose.
How, then, can I uninstall it? Do I need to download a third party uninstall software? Or, does Audacity have a built-in Uninstall feature? If so, where is it? Does it uninstall all related files and code?
If you downloaded the Audacity zip file, (~11Mb), rather than the installer (~19Mb),
you can run Audacity in Windows without it appearing on the list of installed programs. http://www.audacityteam.org/download/windows/
[for future reference, Windows 10 has system-restore, but it’s not on by default ].
