I am building audacity-sources-3.4.2 in Ubuntu 18.04. And it use conan to build.
I downloaded the source code from here. Following the build instructions from here.
- Prerequisites
$ python --version Python 3.9.18 $ cmake --version cmake version 3.27.7 $ g++ --version g++ (Ubuntu 13.1.0-8ubuntu1~18.04) 13.1.0 $ conan --version Conan version 2.0.17 $ sudo apt-get install libgtk2.0-dev libasound2-dev libjack-jackd2-dev uuid-dev Reading package lists… Done Building dependency tree Reading state information… Done libgtk2.0-dev is already the newest version (2.24.32-1ubuntu1). libjack-jackd2-dev is already the newest version (1.9.12~dfsg-2). libasound2-dev is already the newest version (1.1.3-5ubuntu0.6). uuid-dev is already the newest version (2.31.1-0.4ubuntu3.7). 0 upgraded, 0 newly installed, 0 to remove and 32 not upgraded.
- build
$ mkdir build && cd build
$ cmake -G "Unix Makefiles" ..
$ make
[ 42%] Built target lib-command-parameters
[ 42%] Linking CXX shared library ../../Release/lib/audacity/lib-files.so
[ 42%] Built target lib-files
[ 42%] Linking CXX executable ../../../tests/lib-string-utils-test
/home/lili/.conan2/p/wxwid26105d65d2dd5/p/lib/libwx_baseu-3.1.so: undefined reference to `dladdr@GLIBC_2.34'
/home/lili/.conan2/p/wxwid26105d65d2dd5/p/lib/libwx_baseu-3.1.so: undefined reference to `dlclose@GLIBC_2.34'
/home/lili/.conan2/p/wxwid26105d65d2dd5/p/lib/libwx_baseu-3.1.so: undefined reference to `fstat@GLIBC_2.33'
/home/lili/.conan2/p/wxwid26105d65d2dd5/p/lib/libwx_baseu-3.1.so: undefined reference to `dlerror@GLIBC_2.34'
/home/lili/.conan2/p/wxwid26105d65d2dd5/p/lib/libwx_baseu-3.1.so: undefined reference to `pthread_mutexattr_init@GLIBC_2.34'
/home/lili/.conan2/p/wxwid26105d65d2dd5/p/lib/libwx_baseu-3.1.so: undefined reference to `pthread_key_create@GLIBC_2.34'
/home/lili/.conan2/p/wxwid26105d65d2dd5/p/lib/libwx_baseu-3.1.so: undefined reference to `pthread_setspecific@GLIBC_2.34'
/home/lili/.conan2/p/wxwid26105d65d2dd5/p/lib/libwx_baseu-3.1.so: undefined reference to `pthread_join@GLIBC_2.34'
/home/lili/.conan2/p/wxwid26105d65d2dd5/p/lib/libwx_baseu-3.1.so: undefined reference to `pthread_mutex_trylock@GLIBC_2.34'
/home/lili/.conan2/p/wxwid26105d65d2dd5/p/lib/libwx_baseu-3.1.so: undefined reference to `dlsym@GLIBC_2.34'
/home/lili/.conan2/p/wxwid26105d65d2dd5/p/lib/libwx_baseu-3.1.so: undefined reference to `pthread_getspecific@GLIBC_2.34'
/home/lili/.conan2/p/wxwid26105d65d2dd5/p/lib/libwx_baseu-3.1.so: undefined reference to `pthread_key_delete@GLIBC_2.34'
/home/lili/.conan2/p/wxwid26105d65d2dd5/p/lib/libwx_baseu-3.1.so: undefined reference to `lstat@GLIBC_2.33'
/home/lili/.conan2/p/wxwid26105d65d2dd5/p/lib/libwx_baseu-3.1.so: undefined reference to `stat@GLIBC_2.33'
/home/lili/.conan2/p/wxwid26105d65d2dd5/p/lib/libwx_baseu-3.1.so: undefined reference to `dlopen@GLIBC_2.34'
/home/lili/.conan2/p/wxwid26105d65d2dd5/p/lib/libwx_baseu-3.1.so: undefined reference to `pthread_mutexattr_settype@GLIBC_2.34'
/home/lili/.conan2/p/wxwid26105d65d2dd5/p/lib/libwx_baseu-3.1.so: undefined reference to `pthread_create@GLIBC_2.34'
collect2: error: ld returned 1 exit status
libraries/lib-string-utils/tests/CMakeFiles/lib-string-utils-test.dir/build.make:115: recipe for target 'tests/lib-string-utils-test' failed
make[2]: *** [tests/lib-string-utils-test] Error 1
CMakeFiles/Makefile2:2265: recipe for target 'libraries/lib-string-utils/tests/CMakeFiles/lib-string-utils-test.dir/all' failed
make[1]: *** [libraries/lib-string-utils/tests/CMakeFiles/lib-string-utils-test.dir/all] Error 2
[ 42%] Linking C static library libsqlite.a
[ 42%] Built target sqlite
[ 43%] Linking CXX executable ../../../tests/lib-utility-test
[ 43%] Built target lib-utility-test
Makefile:165: recipe for target 'all' failed
make: *** [all] Error 2
my glibc version:
$ ldd --version
ldd (Ubuntu GLIBC 2.27-3ubuntu1.6) 2.27
