Unable to see audio wave form for 32-bit float recording
As an owner of a GoPro HERO 5 Black I suffer from the lack of documentation regarding “raw audio”:
I can get an MP4 video with stereo sound (“GoPro AVC”) plus an extra WAV file with four mono channels recorded with 32-bit floating point (“pcm_s32le”) at 48 kHz.
As the HERO 5 has only three microphones (according to the manual), I tried to find out the channel mapping by recording a short video while moving a sound source around.
However the WAV file’s recording level is very low:
Much lower than -48dB it seems.
My problem now is:
How can I “preview” the audio wave before trying to normalize?
I could successfully “zoom in”, but that did not help.
How can I see the wave form?
I’m only an occasional user of audacity, so I might be missing something obvious.
Should I “zoom out” instead?
However I’m hitting the -48dB limit and I didn’t find the setting to change it.
Shouldn’t Audacity (2.4.2 is the version I’m using) adjust automatically for 32-bit float resolution?
After normalizing the wave-forms to -20dB, I see this (probably quite some quantization errors):
Try the Amplify or Normalize effect. You might have to Amplify twice because there is a 50dB limit. Floating point can go that low without loosing quality so amplifying is worth a try, but there probably is something else wrong. :frowning:
If the data is scrambled or decoded incorrectly you’ll almost always get full-volume noise noise so it probably really is that quiet (or silent).
Yes. The WAV file header tells the software what format you have. The data is scaled automatically by the software and/or drivers 0dB is the same volume in floating point, 24-bit or 8-bit, etc, (even though the “numbers” are different). By default, Audacity works in 32-bit floating-point “internally” so when you open a file or record it gets converted to floating point (if i’s not already). Then when you play it, the drivers convert it an integer format that matches the bit-depth of your digital-to-analog converter.
Thanks for the response, but what I wanted to do was to “zoom in” until I can see some audio.
The audio is obviously there, while being very silent. Maybe it’s a firmware bug in the GoPro.
See here in the manual: Vertical Zooming - Audacity Manual
I was able to solve the problem, and it looks like a bug in Audacity:
I had changed the the resolution of the playback meter from -48dB to -120dB. The scale changed, but the displayed wave shapes did not.
However when starting Audacity the next time, the wave shapes were scaled from -120dB, too!
Are you at liberty to post your MP4? If not, could you create one you could post ? Perhaps someone will be able to replicate your issue…
