Just installed Audacity 3.1.3 Downloaded and installed “FFmpeg for Audacity” as recommended Went to Audacity preferences and located “avformat-55.dll” correctly but the software does not detect it.
I added the programs log file.
Thank you audacitylog.txt (5.25 KB)
Are you running the 64-bit version of Audacity or the 32-bit version?
For the 64-bit version you need to install [u]FFmpeg_v2.2.2_for_Audacity_on_Windows_64bit.exe[/u].
Thank you. You’re right, I was running 32bit ffmpeg on audacity 64bit. Now it’s working perfect
