I have Installed Audacity 3.5.0 in Windows 10 , Removed folders of OpenVino, and %appdata%\audacity and did everything I could but Open Vino is NOT working in Windows 10. Earlier Version its working as expected.
In Preference >Module >Open Vino - Failed
Done enabling that also still its not showing after restarting the machine.
Have you downloaded the new version of OpenVino as well?
The easiest way to install is to download the two zip files below ([Audacity-OpenVINO-Module-3.4.2-R1.zip] I have this Versions with me
Well, that’s the version that works with Audacity 3.4.2. The new one, called 3.5.0-R2 is here: Releases · intel/openvino-plugins-ai-audacity · GitHub
Now they have given bundled exe trying that one. Thanks
@LWinterberg It worked after Installing the plugin (audacity-win-v3.5.0-R2-64bit-OpenVINO-AI-Plugins) Thank you very much
