Unable to install Audacity. Universal DMG or ARM 64?
Hello,
I just joined and attempted to install Audacity.
After running the installer, a ‘Welcome to Musehub’ window pops up and then immediately crashes.
The installer shows that the installation was successful, but Audacity is nowhere to be found.
I used the Audacity Installer (recommended). Should I have used the Universal DMG or ARM 64 instead?
I’m using an M1 Mac mini and OS 15.5
Thanks for any advice.
-Metro
I would recommend installing the version of Audacity without Musehub. It is unfortunate that you have to go looking for that, and the version with Musehub is very prominent, but I guess I can see why the company does that. They are in business to support themself financially.
Thanks Wrecks, I’ll give it a go.
All the best
-Metrobot
