Hey everyone
Been using Audacity for a long time and never had this problem.
I want to export my file into mp3 and i get the following message “unable to export” then when i press ok, it says “export done with error” (on the screenshots, it’s in french).
Tried exporting in wav, and changing the locations, same problem.
Even tried different audacity versions, doesn’t work either.
Thanks for your help !
Perhaps the problem is that you are attempting to export to OneDrive, which is not a “normal” directory.
Hey! Nope not that, tried different locations and it didn’t work anyway
